Salta al contenuto principale
Acer Nitro 5 AN515-55-55M1 Battery Replacement
Cosa ti serve
  1. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Battery Replacement: passo 2, immagine 1 di 2 Acer Nitro 5 AN515-55-55M1 Battery Replacement: passo 2, immagine 2 di 2
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: passo 3, immagine 1 di 3 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: passo 3, immagine 2 di 3 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Battery Replacement: passo 4, immagine 1 di 2 Acer Nitro 5 AN515-55-55M1 Battery Replacement: passo 4, immagine 2 di 2
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
Conclusione
Congratulations! You have successfully replaced the battery of your Acer Nitro 5 AN515-55-55M1!
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 208
Tutti i Tempi: 11,003
