Salta al contenuto principale
Acer Nitro 5 AN515-53-55G9 Touchpad Replacement
Cosa ti serve
  1. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: passo 1, immagine 1 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: passo 1, immagine 2 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 2, immagine 1 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 2, immagine 2 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 2, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 3, immagine 1 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 3, immagine 2 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 3, immagine 3 di 3
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 5, immagine 1 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 5, immagine 2 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 5, immagine 3 di 3
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 6, immagine 1 di 2 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 6, immagine 2 di 2
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
  7. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 7, immagine 1 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 7, immagine 2 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 7, immagine 3 di 3
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 8, immagine 1 di 1
    • Remove battery from device.
  9. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Touchpad: passo 9, immagine 1 di 2 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Touchpad: passo 9, immagine 2 di 2
    • Locate the Touchpad in the lower middle of the device.
    • Locate and remove the 4mm screws that hold the Touchpad in place.
  10. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 10, immagine 1 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 10, immagine 2 di 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 10, immagine 3 di 3
    • Locate the Touchpad's connector.
    • Use a plastic spudger to pry up the small plastic clip on the connector port.
    • Gently pull the cable out of the port.
  11. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: passo 11, immagine 1 di 1
    • Lift up the Touchpad and remove it from the device.
Conclusione
Altre 5 persone hanno completato questa guida.
2 Commenti
And where can I find the track pad replacement? Thanks.
xRiiad _YouTube - Replica
You can purchase replacement trackpads online, on eBay or Amazon or many other places by simply Google searching “Acer Nitro 5 Touchpad Part”
Rheo Bruer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 60
Tutti i Tempi: 5,026
