Introduzione
In this guide, you will be instructed on how to replace the hard drive on your laptop. Your hard drive acts as a long-term memory for your computer, and the greater your hard drive’s capacity, the more work you can store on your computer.
If you are curious of how much space you currently have, check this link out.
Cosa ti serve
Place the laptops with bottom facing up.
Use a Phillips #0 screwdriver to remove the single 4.0 mm screw holding the black plastic HDD cover.
Use the pry tool to remove the black plastic HDD cover.
