Salta al contenuto principale
Acer Nitro 5 AN515-53-52FA Fan Replacement
Cosa ti serve
  1. Acer Nitro 5 AN515-53-52FA Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up
  2. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 2, immagine 1 di 2 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 3, immagine 1 di 2 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
    • Removing the backshell of the laptop will reveal the inside of it.
    • The fan of the laptop is located on the top left of the laptop.
  4. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 4, immagine 1 di 2 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 4, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the four 9 mm screws securing the fans.
  5. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 5, immagine 1 di 3 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 5, immagine 2 di 3 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 5, immagine 3 di 3
    • Unplug the connectors before taking the fan out.
  6. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 6, immagine 1 di 2 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 6, immagine 2 di 2
    • Gently remove the fans from the adhesive strip.
Conclusione
Altre 3 persone hanno completato questa guida.
Gateway, Team 1-3, Pee Fall 2022 Membro di Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
4 Membri
5 Guide realizzate
Un commento
thank you so much
Muhammet Enes Utku - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 46
Tutti i Tempi: 910
