Salta al contenuto principale
Acer Nitro 5 AN515-53-52FA Battery Replacement
Cosa ti serve
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 2, immagine 1 di 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 3, immagine 1 di 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 3, immagine 2 di 2
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 5, immagine 1 di 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 6, immagine 1 di 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 6, immagine 2 di 2
    • Lift the battery up and out of the laptop.
Conclusione
Gateway, Team 1-3, Pee Fall 2022 Membro di Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
4 Membri
5 Guide realizzate
2 Commenti
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - Replica
Can I use a Jimmy instead of the opening picks?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 73
Tutti i Tempi: 940
