Introduzione
If you forgot your password, PIN, pattern drill, or if you have problem with your Android OS, you can make a Factory / Hard reset.
Panoramica Video
Power off the tablet. Press and hold the Volume Up and the Power button. After 3 seconds release the Power On button but continue holding the Volume Up button. In the Select Boot Mode use the Volume Up/Down keys to navigate and the Power button to select the desired option.
[SD Image Update Mode]
wipe data/factory reset
Yes - delete all user data
Reboot system now.
Your tablet will reboot and go to the Welcome screen.
Altre 41 persone hanno completato questa guida.
23 Commenti
This is not workin it keep saying enter the email .... n when dun its still not going in
I did this and the tablet is stuck at the logo !
I have done this. But I'm stuck at email address I use when i first bought. I don't remember my email address. What can I do
Yep I am having the same problem and have done all kinds of searching on how to override it or some other fix...
Does not work... Acer does not have a solution.... but money of course !
It stuck on welcome page and I can topen it
My Acer lconia tablet was reset. What I can do
Did this process with a few tweaks…and it hung on the Acer logo, so I powered off and back on and began the start up process. Great advice and it worked perfectly!
This is for Crystal W. Bishop or anyone who has successfully reset the Acer 10 Iconic Tablet getting to bypass the fast boot screen. I can't pull up the SD menu. Please help
Thank you. parker.suzan@yahoo.com
I am stuck on the icon with tje red triangle with a ! In it. Pls help
It went to the welcome screen but it wants me to enter numbers to unlock. I dont know what numbers it was set up with.
Help
My battery keeps getting too hot
My battery keeps over
My battery keeps overheating
I did everything I had to wait for 24 hours did that still nothing happen so frustrating
Don’t know password and the steps don’t work
I pushed on power and volume up but all it does is stuck on Intel inside, I need to know where to get a factory power charger for sind number 42302324786 can someone please please help me
It don't work
when i reboot it it has an red traingle
Khia Ragin - Replica
Hahaha thanks it worked for me im so grateful
Jennifer Hill - Replica
My tab cannot ON....what happen, what should I do?
Zamri - Replica
Awesome thanks a lot it worked on my tablet
alina - Replica
it will not working even i try bypass way give me some another trick
Kings Order - Replica
on my tablet I did what you said but all I got was in tiny letters bottom left was =FASTBOOT mode… any suggestions but this is a acer iconica one 10
norma goddard - Replica
acer iconica one 10 it will not do any other suggestions all I got was in tiny print bottom left corner was = fastboot mode
Mine just stays in the welcome screen…any ideas?
recroom55 - Replica
After hitting reboot the tablet just stays on the welcome screen…thoughts?
recroom55 - Replica
did not work saids acer that it
ken - Replica
Does this wipe apps and stuff?
Freya the Irish dancer - Replica
If your tablet don’t come on after the reset what’s wrong with it
kris_green8662 - Replica
it worked on my Model # A1311. Thank you!
Al Cohen - Replica
mine had just reboot then asked me to input my google or gmail account i had put it in but it says..unable to access email and it needs 24 hrs..after 2 days i did it again but to no avail anothe day had passed i do it again and again but still pemail and oassword wont work
Theresa Dela Cruz - Replica
Does this delete all my pictures,?
jlewis9797 - Replica
I have a BLUE SCREEN and a flashing symbol.
Karl Gunnell - Replica
please respond quickly ??
I have an acer iconia one 7 and ive hard reset it but ove forgotten the email the device was set up with and i cant sign in 😪 any suggestions??
Nathan - Replica
No factory reset
jayanthi k - Replica
