Salta al contenuto principale
Acer Iconia Tab B1 Factory Hard Reset/Password Removal
Panoramica Video
  1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 1, immagine 1 di 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 1, immagine 2 di 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 1, immagine 3 di 3
    • From the reset hole we can make reset without erasing data.
  2. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 2, immagine 1 di 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 2, immagine 2 di 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 2, immagine 3 di 3
    • Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time.
  3. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 3, immagine 1 di 2 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 3, immagine 2 di 2
    • Now you are in the Boot Mode menu. With Vol(+), (-) go to [SD Update Image Mode] and select it with Power On key.
    • Pressing the Power On key too quickly may turn off the tablet screen. You'll need to press and hold for about a second to select [SD Update Image Mode].
  4. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 4, immagine 1 di 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 4, immagine 2 di 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 4, immagine 3 di 3
    • Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now".
  5. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 5, immagine 1 di 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 5, immagine 2 di 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: passo 5, immagine 3 di 3
    • After restart you will have empty (free of data) device and access to it.
Conclusione
Altre 11 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.308 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.535 Guide realizzate
2 Commenti
I have a problem when it came to SD image update mode I get the log acer restarts does not pass the second part you have any idea?
tengo un problema cuando entró a SD image update mode me sale el log de acer se reinicia no pasa a la segunda parte tienes alguna idea ?
martinez1816 - Replica
I have the same problem when it came to SD image update mode I get the acer logo and it restarts it does not pass to the android logo it geast restart
Claudiu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 70,692
