Salta al contenuto principale
Acer Iconia Tab A501 Wireless Adapter Replacement
Cosa ti serve
  1. Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: passo 1, immagine 3 di 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Wireless Adapter Replacement: passo 2, immagine 1 di 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: passo 3, immagine 1 di 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: passo 3, immagine 2 di 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    $3.99
    Compra
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 Wireless Adapter Replacement: passo 4, immagine 1 di 1
    • Remove all tape covering the wireless adapter.
  5. Acer Iconia Tab A501 Wireless Adapter Replacement: passo 5, immagine 1 di 3 Acer Iconia Tab A501 Wireless Adapter Replacement: passo 5, immagine 2 di 3 Acer Iconia Tab A501 Wireless Adapter Replacement: passo 5, immagine 3 di 3
    • Use the flat end of the standard Spudger to disconnect the two small rotatable connectors attached to the wireless adapter.
  6. Acer Iconia Tab A501 Wireless Adapter Replacement: passo 6, immagine 1 di 2 Acer Iconia Tab A501 Wireless Adapter Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
  7. Acer Iconia Tab A501 Wireless Adapter Replacement: passo 7, immagine 1 di 2 Acer Iconia Tab A501 Wireless Adapter Replacement: passo 7, immagine 2 di 2
    • Carefully slide the adapter out to remove it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 353
