Salta al contenuto principale
Acer Iconia Tab A501 Back Cover Replacement
Cosa ti serve
  1. Acer Iconia Tab A501 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Iconia Tab A501 Back Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Iconia Tab A501 Back Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Back Cover Replacement: passo 2, immagine 1 di 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 214
