Introduzione
This guide will provide step by step instructions on how to replace the screen on an Acer Iconia Tab A500.
Parti
Nessuna parte specificata.
To start, gently separate one corner of the case using the black spudger.
Remove the 5mm screws that are securing the battery to the rest of the tablet.
Use the Phillips #00 Screwdriver to remove the 5mm screws.
Locate the 4 screws and cable that hold in the two speakers.
Use the Phillips #1 screwdriver to remove these 2mm black screws.
Remove the 2mm silver screws.
Connector Cable
Using the Phillips #1 screwdriver, remove the screws near the edges of the tablet.
Remove this components near the edge of the tablet by unscrewing the 5mm screw holding the top in place.
Altre 7 persone hanno completato questa guida.
