Introduzione
Heres how to get out your motherboard, if you want to solder on a new power button, or simply replace the whole thing.
Cosa ti serve
To start, gently separate one corner of the case using the black spudger.
Locate the 4 screws and cable that hold in the two speakers.
Use the Phillips #1 screwdriver to remove these 2mm black screws.
Remove the 2mm silver screws.
Remove the 5mm screws that are securing the battery to the rest of the tablet.
Use the Phillips #00 Screwdriver to remove the 5mm screws.
Using the Phillips #1 screwdriver, remove the screws near the edges of the tablet.
Having disconnected all those pesky cables, the motherboard lifts cleanly out.
From here, you can solder on a new switch or put in the new motherboard. To reassemble your device, follow these instructions in reverse order.
Altre 20 persone hanno completato questa guida.
