Introduzione
The Acer Iconia Tab A200 has a 10.1" Touchscreen display.
Cosa ti serve
With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
Using the plastic opening tool gently lift up the charging component out of its slot in the case.
Lift up on the microphone cable to lift the microphone component away from the case.
After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place.
Using the plastic opening tool unplug the green cable by placing the tool under where the cable meets the plug and lifting up.
After unplugging the green cable remove the black tape that secures the green cable to motherboard.
Using the pointed tip of the nylon spudger, pry the unit board off the case
Altre 4 persone hanno completato questa guida.
2 Commenti
Looking forward to fixing this tablet a friend had given up on then gave to me. So funny how easily ppl give up!Thank you for this spectacular set of directions. Looks like it will be the one that works for the tablet I have.
how can i tell if there is any water damage?
