Introduzione
The DC power jack component is used to charge the Acer tablet. The component is approximately 8 inches in length and connects to the motherboard to supply power to the device.
Cosa ti serve
With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
Using the plastic opening tool gently lift up the charging component out of its slot in the case.
Altre 3 persone hanno completato questa guida.
2 Commenti
Probably no need to REPLACE the jack. Just push the little indented tabs in a fraction of a millimeter and it will make good contact again. I just did this with mine and it works perfectly now after having been a royal PITA for over a year.
