Salta al contenuto principale
Acer Iconia Tab 8 A1-860 Speaker Replacement
Cosa ti serve
  1. Acer Iconia Tab 8 A1-860 Speaker Replacement, Rear Case: passo 1, immagine 1 di 2 Acer Iconia Tab 8 A1-860 Speaker Replacement, Rear Case: passo 1, immagine 2 di 2
    • Insert the plastic opening tool into the seam between the back case and the display.
    • Work the plastic opening tool around the seam until the rear case separates from the display.
  2. Acer Iconia Tab 8 A1-860 Speaker Replacement: passo 2, immagine 1 di 1
    • Separate the rear case and place the tablet face side down.
  3. Acer Iconia Tab 8 A1-860 Speaker Replacement, Battery: passo 3, immagine 1 di 1
    • Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
  4. Acer Iconia Tab 8 A1-860 Speaker Replacement: passo 4, immagine 1 di 3 Acer Iconia Tab 8 A1-860 Speaker Replacement: passo 4, immagine 2 di 3 Acer Iconia Tab 8 A1-860 Speaker Replacement: passo 4, immagine 3 di 3
    • Pull firmly on the black tabs, located at the top left and bottom right of the battery.
    • The clear adhesive strips attached to the tabs are quite stretchy. Don't give up; keep pulling the tabs until the battery releases. The strips will not be reusable.
    • Remove the battery.
  5. Acer Iconia Tab 8 A1-860 Speaker Replacement, Speaker: passo 5, immagine 1 di 2 Acer Iconia Tab 8 A1-860 Speaker Replacement, Speaker: passo 5, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws.
  6. Acer Iconia Tab 8 A1-860 Speaker Replacement: passo 6, immagine 1 di 2 Acer Iconia Tab 8 A1-860 Speaker Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to gently lift off the connector and wires attached to the speakers.
    • Remove the speakers from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S2-G3, Harley Spring 2019 Membro di IUPUI, Team S2-G3, Harley Spring 2019
IUPUI-HARLEY-S19S2G3
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 149
