Salta al contenuto principale
Acer Iconia Tab 8 A1-860 Motherboard Replacement
Cosa ti serve
  1. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Rear Case: passo 1, immagine 1 di 2 Acer Iconia Tab 8 A1-860 Motherboard Replacement, Rear Case: passo 1, immagine 2 di 2
    • Insert the plastic opening tool into the seam between the back case and the display.
    • Work the plastic opening tool around the seam until the rear case separates from the display.
  2. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 2, immagine 1 di 1
    • Separate the rear case and place the tablet face side down.
  3. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Battery: passo 3, immagine 1 di 1
    • Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
  4. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 4, immagine 1 di 3 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 4, immagine 2 di 3 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 4, immagine 3 di 3
    • Pull firmly on the black tabs, located at the top left and bottom right of the battery.
    • The clear adhesive strips attached to the tabs are quite stretchy. Don't give up; keep pulling the tabs until the battery releases. The strips will not be reusable.
    • Remove the battery.
  5. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 Acer Iconia Tab 8 A1-860 Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Using the spudger, remove the two tabs shown by placing the spudger under the gray part of the connectors and pulling on the tabs.
  6. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the three 2 mm screws.
  7. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 7, immagine 1 di 2 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the spudger, push the tab where this belt connects to the motherboard to free it.
    • Use tweezers in order to pull the belt from its slot in the motherboard.
  8. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 8, immagine 1 di 2 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 8, immagine 2 di 2
    • Using the spudger, push the tab connecting this belt to the motherboard.
    • Once the tab is pushed and the belt is free to move, use tweezers to pull it from the slot.
  9. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 9, immagine 1 di 3 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 9, immagine 2 di 3 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 9, immagine 3 di 3
    • Using tweezers, pull upward on the end of this belt where it plugs into the motherboard.
  10. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 10, immagine 1 di 3 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 10, immagine 2 di 3 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 10, immagine 3 di 3
    • With the tweezers, grab the gray wire and move it from underneath the plastic piece shown in red.
    • Then place the tweezers on the end of the wire circled, and pull the piece from the motherboard.
  11. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 11, immagine 1 di 3 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 11, immagine 2 di 3 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 11, immagine 3 di 3
    • Use tweezers in order to lift a corner of this copper foil.
    • Then use a spudger to pull the copper foil from the motherboard.
    • If the copper foil does not remove easily, use an iOpener heating pad to release the adhesive.
  12. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 12, immagine 1 di 2 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 12, immagine 2 di 2
    • Using tweezers, remove the "void" sticker to reveal a 3 mm screw.
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws.
  13. Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 13, immagine 1 di 2 Acer Iconia Tab 8 A1-860 Motherboard Replacement: passo 13, immagine 2 di 2
    • Carefully lift the motherboard out of its slot in the rear case.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team S2-G3, Harley Spring 2019 Membro di IUPUI, Team S2-G3, Harley Spring 2019
IUPUI-HARLEY-S19S2G3
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 447
