Salta al contenuto principale
Acer Iconia Tab 8 A1-840 Front Camera Replacement
Cosa ti serve
  1. Acer Iconia Tab 8 A1-840 Front Camera Replacement, Back Panel: passo 1, immagine 1 di 1
    • Power off the device
    • Remove any cables that might be connected to your device
    • Make sure the device is placed on a flat surface with the display screen facing up
  2. Acer Iconia Tab 8 A1-840 Front Camera Replacement: passo 2, immagine 1 di 1
    • Wedge the plastic opening tool in between the display screen and back panel
    • Do not apply too much pressure in order to avoid cracking the screen
  3. Acer Iconia Tab 8 A1-840 Front Camera Replacement: passo 3, immagine 1 di 1
    • Carefully separate the display from the back panel
  4. Acer Iconia Tab 8 A1-840 Front Camera Replacement, Front Camera: passo 4, immagine 1 di 1
    • Use the spudger to lift the the black flap.
  5. Acer Iconia Tab 8 A1-840 Front Camera Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the ESD safe precision tweezers to pull the connector out and carefully remove the camera.
Conclusione
UW Tacoma, Team 1-1, Rose Fall 2016 Membro di UW Tacoma, Team 1-1, Rose Fall 2016
UWT-ROSE-F16S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 402
