Salta al contenuto principale
Acer Iconia One 8 Rear Camera Replacement
Cosa ti serve
  1. Acer Iconia One 8 Rear Camera Replacement, Rear Camera: passo 1, immagine 1 di 2 Acer Iconia One 8 Rear Camera Replacement, Rear Camera: passo 1, immagine 2 di 2
    • The first step to replacing the rear camera on your Acer tablet is to remove the Back Panel. To do that, use your iFixit opening tool to pry open the device in the small crevice. Do this gently in order not to crack the screen on your tablet.
  2. Acer Iconia One 8 Rear Camera Replacement: passo 2, immagine 1 di 1
    • To remove the ZIF connector on the rear camera, gently use the flat end of your spudger to lift it up and free the rear camera.
  3. Acer Iconia One 8 Rear Camera Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • In order to gently remove the camera, grab the precision tweezers and carefully pull out the connector to remove the camera.
Conclusione
Un commento
Hola, podrías hacer un post sobre cómo arreglar el toque, gracias.
chevas-carrillo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 405
