Salta al contenuto principale
Acer Iconia One 8 Battery Replacement
Cosa ti serve
  1. Acer Iconia One 8 Battery Replacement, Battery: passo 1, immagine 1 di 2 Acer Iconia One 8 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: passo 3, immagine 1 di 1
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: passo 4, immagine 1 di 1
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,943
