Salta al contenuto principale
Acer Iconia One 7 Speaker Replacement
Cosa ti serve
  1. Acer Iconia One 7 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult; use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Speaker Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Speaker Replacement: passo 3, immagine 1 di 1
    • Turn the tablet over to locate the speaker.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
    • The speaker is on the bottom of the inside.
  4. Acer Iconia One 7 Speaker Replacement: passo 4, immagine 1 di 2 Acer Iconia One 7 Speaker Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Peel back tape.
    • Using tweezers, detach connection from motherboard.
  5. Acer Iconia One 7 Speaker Replacement: passo 5, immagine 1 di 3 Acer Iconia One 7 Speaker Replacement: passo 5, immagine 2 di 3 Acer Iconia One 7 Speaker Replacement: passo 5, immagine 3 di 3
    • Unscrew screws with a JIS screwdriver with a #00 screw bit.
    • Dislodge the speaker unit.
    • Take care not to displace any other bits in the device.
Conclusione
Michael
Membro da: 09/03/15
519 Reputazione
4 Guide realizzate
USF Tampa, Team 8-5, Eyestone Fall 2015 Membro di USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 21
Tutti i Tempi: 449
