Salta al contenuto principale
Acer Iconia One 7 Motherboard Replacement
Cosa ti serve
    • Reminder: Turn off device before you start opening your tablet.
  1. Acer Iconia One 7 Motherboard Replacement: passo 2, immagine 1 di 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Use caution when prying the lid open to avoid damaging your tablet.
  2. Acer Iconia One 7 Motherboard Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, separate the back cover from the main device
    • Open each side continuously to ensure all sides have been separated,
  3. Acer Iconia One 7 Motherboard Replacement: passo 4, immagine 1 di 1
    • Turn tablet over.
    • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
  4. Acer Iconia One 7 Motherboard Replacement: passo 5, immagine 1 di 1
    • Carefully peel back the copper foil to reveal the motherboard.
  5. Acer Iconia One 7 Motherboard Replacement: passo 6, immagine 1 di 1
    • Peel tape back to expose connections.
  6. Acer Iconia One 7 Motherboard Replacement: passo 7, immagine 1 di 2 Acer Iconia One 7 Motherboard Replacement: passo 7, immagine 2 di 2
    • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
  7. Acer Iconia One 7 Motherboard Replacement: passo 8, immagine 1 di 2 Acer Iconia One 7 Motherboard Replacement: passo 8, immagine 2 di 2
    • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
  8. Acer Iconia One 7 Motherboard Replacement: passo 9, immagine 1 di 1
    • Gently pull out motherboard.
Conclusione
Altre 4 persone hanno completato questa guida.
Michael
Membro da: 09/03/15
519 Reputazione
4 Guide realizzate
USF Tampa, Team 8-5, Eyestone Fall 2015 Membro di USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,568
