Salta al contenuto principale
Acer Iconia One 7 Battery Replacement
Cosa ti serve
  1. Acer Iconia One 7 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
  2. Acer Iconia One 7 Battery Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Battery Replacement: passo 3, immagine 1 di 1
    • Turn the tablet over so the battery is facing up.
  4. Acer Iconia One 7 Battery Replacement: passo 4, immagine 1 di 2 Acer Iconia One 7 Battery Replacement: passo 4, immagine 2 di 2
    • Carefully pull back the black tape covering the battery lead connector.
    • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
  5. Acer Iconia One 7 Battery Replacement: passo 5, immagine 1 di 3 Acer Iconia One 7 Battery Replacement: passo 5, immagine 2 di 3 Acer Iconia One 7 Battery Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Using a plastic card or opening pick, separate the battery from the rest of the device.
    • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 8-5, Eyestone Fall 2015 Membro di USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Membri
5 Guide realizzate
4 Commenti
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - Replica
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - Replica
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - Replica
Where I can order the new battery part?
melanieloa3 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 48
Tutti i Tempi: 18,277
