Salta al contenuto principale
Acer Iconia One 10 B3-A30 Repair Motherboard Replacement
Cosa ti serve
  1. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 2, immagine 1 di 3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 2, immagine 2 di 3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 2, immagine 3 di 3
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 4, immagine 1 di 2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 4, immagine 2 di 2
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 5, immagine 1 di 3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 5, immagine 2 di 3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 5, immagine 3 di 3
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  6. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Remove all of the tape surrounding the motherboard.
  7. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 7, immagine 1 di 2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 7, immagine 2 di 2
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  8. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 8, immagine 1 di 1
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  9. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 9, immagine 1 di 2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: passo 9, immagine 2 di 2
    • Using the small plastic tool, carefully pry the motherboard out of the device.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S1-G5, Nance Fall 2017 Membro di USF Tampa, Team S1-G5, Nance Fall 2017
USFT-NANCE-F17S1G5
4 Membri
5 Guide realizzate
Un commento
The button flex cable retaining clip is broken, do you have this available?
Craig Olmscheid - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,841
