Salta al contenuto principale
Acer Iconia B1-711 LCD Display Replacement
Cosa ti serve
Panoramica Video
  1. Acer Iconia B1-711 LCD Display Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Iconia B1-711 LCD Display Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Iconia B1-711 LCD Display Replacement, Back Cover: passo 1, immagine 3 di 3
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 LCD Display Replacement: passo 2, immagine 1 di 2 Acer Iconia B1-711 LCD Display Replacement: passo 2, immagine 2 di 2
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 LCD Display Replacement, Battery: passo 3, immagine 1 di 2 Acer Iconia B1-711 LCD Display Replacement, Battery: passo 3, immagine 2 di 2
    • With a long plastic tool like a spudger, unstick the battery from the metal LCD shield.
    • Lithium Ion Battery Pack - 3.8V, 2710mAh
  4. Acer Iconia B1-711 LCD Display Replacement, Audio Jack Connector: passo 4, immagine 1 di 3 Acer Iconia B1-711 LCD Display Replacement, Audio Jack Connector: passo 4, immagine 2 di 3 Acer Iconia B1-711 LCD Display Replacement, Audio Jack Connector: passo 4, immagine 3 di 3
    • Unscrew 2x Philips screws
    • Disconnect and remove the Audio Jack Board flex cable.
    • Remove the board with the Audio Jack Connector.
  5. Acer Iconia B1-711 LCD Display Replacement, Camera: passo 5, immagine 1 di 3 Acer Iconia B1-711 LCD Display Replacement, Camera: passo 5, immagine 2 di 3 Acer Iconia B1-711 LCD Display Replacement, Camera: passo 5, immagine 3 di 3
    • Remove the Audio jack flex cable.
    • Remove the metal plate which is placed on the camera connector.
    • Disconnect the camera flex cable.
  6. Acer Iconia B1-711 LCD Display Replacement: passo 6, immagine 1 di 1
    • Remove the camera.
  7. Acer Iconia B1-711 LCD Display Replacement, Microphone: passo 7, immagine 1 di 3 Acer Iconia B1-711 LCD Display Replacement, Microphone: passo 7, immagine 2 di 3 Acer Iconia B1-711 LCD Display Replacement, Microphone: passo 7, immagine 3 di 3
    • Remove the tape from the microphone.
    • Disconnect the Microphone wires and remove the Microphone.
  8. Acer Iconia B1-711 LCD Display Replacement, Logic Board: passo 8, immagine 1 di 3 Acer Iconia B1-711 LCD Display Replacement, Logic Board: passo 8, immagine 2 di 3 Acer Iconia B1-711 LCD Display Replacement, Logic Board: passo 8, immagine 3 di 3
    • Remove the green rubber and disconnect the touch screen flex cable.
    • Disconnect the 4 coaxial antenna cables (Wi-Fi, GPS, 3G).
    • Carefully unstuck the metal folio from the LCD display flex cable.
    • Remove the 3x Phillips screws.
  9. Acer Iconia B1-711 LCD Display Replacement: passo 9, immagine 1 di 3 Acer Iconia B1-711 LCD Display Replacement: passo 9, immagine 2 di 3 Acer Iconia B1-711 LCD Display Replacement: passo 9, immagine 3 di 3
    • Lift the board from the side of the battery connector and turn it around the display connector on 360 degrees.
    • Be careful for the flex cable!
    • Disconnect the LCD display flex cable.
  10. Acer Iconia B1-711 LCD Display Replacement: passo 10, immagine 1 di 2 Acer Iconia B1-711 LCD Display Replacement: passo 10, immagine 2 di 2
    • This is the Logic board.
  11. Acer Iconia B1-711 LCD Display Replacement, LCD Display: passo 11, immagine 1 di 2 Acer Iconia B1-711 LCD Display Replacement, LCD Display: passo 11, immagine 2 di 2
    • Careful unstuck the metal folio from the screen shield.
    • Remove the 4x Phillips screws.
  12. Acer Iconia B1-711 LCD Display Replacement: passo 12, immagine 1 di 3 Acer Iconia B1-711 LCD Display Replacement: passo 12, immagine 2 di 3 Acer Iconia B1-711 LCD Display Replacement: passo 12, immagine 3 di 3
    • lift the screen shield from one side and open it like a door, then remove it.
  13. Acer Iconia B1-711 LCD Display Replacement: passo 13, immagine 1 di 3 Acer Iconia B1-711 LCD Display Replacement: passo 13, immagine 2 di 3 Acer Iconia B1-711 LCD Display Replacement: passo 13, immagine 3 di 3
    • The LCD display is held from the metal screen frame by several locking clips.
    • Very careful using a tool with sharp edge, release the screen from the one side.
  14. Acer Iconia B1-711 LCD Display Replacement: passo 14, immagine 1 di 3 Acer Iconia B1-711 LCD Display Replacement: passo 14, immagine 2 di 3 Acer Iconia B1-711 LCD Display Replacement: passo 14, immagine 3 di 3
    • Lift the display up and remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.341 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.541 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,348
