Introduzione
Acer Iconia B1-710 B1-711 - How to disassemble, take apart the device and replace the broken screen.
Please SUBSCRIBE to my channel ツ
Panoramica Video
Switch-off the tablet.
  • Switch-off the tablet.
  • Remove any SIM and/or Memory Card.
  • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
  • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
  • Disconnect the Loudspeaker cable from the Logic board.
Aggiungi Commento
Before doing anything, disconnect the battery.
Aggiungi Commento
Aggiungi Commento
Aggiungi Commento
  • Remove the Audio jack flex cable.
  • Remove the metal plate which is placed on the camera connector.
  • Disconnect the camera flex cable.
Aggiungi Commento
Aggiungi Commento
Aggiungi Commento
  • Remove the green rubber and disconnect the touch screen flex cable.
  • Disconnect the 4 coaxial antenna cables (Wi-Fi, GPS, 3G).
  • Carefully unstuck the metal folio from the LCD display flex cable.
  • Remove the 3x Phillips screws.
Aggiungi Commento
  • Lift the board from the side of the battery connector and turn it around the display connector on 360 degrees.
  • Be careful for the flex cable!
  • Disconnect the LCD display flex cable.
Aggiungi Commento
Aggiungi Commento
  • Careful unstuck the metal folio from the screen shield.
  • Remove the 4x Phillips screws.
Aggiungi Commento
  • lift the screen shield from one side and open it like a door, then remove it.
Aggiungi Commento
  • The LCD display is held from the metal screen frame by several locking clips.
  • Very careful using a tool with sharp edge, release the screen from the one side.
Aggiungi Commento
Aggiungi Commento
Conclusione
ZFix
Membro da: 09/12/2013
154.663 Reputazione
436 Guide realizzate
Master Techs Membro di Master Techs
Community
277 Membri
730 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,761
