Salta al contenuto principale
Acer Iconia B1-711 Audio Jack Connector Replacement
Cosa ti serve
Panoramica Video
  1. Acer Iconia B1-711 Audio Jack Connector Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Iconia B1-711 Audio Jack Connector Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Iconia B1-711 Audio Jack Connector Replacement, Back Cover: passo 1, immagine 3 di 3
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 Audio Jack Connector Replacement: passo 2, immagine 1 di 2 Acer Iconia B1-711 Audio Jack Connector Replacement: passo 2, immagine 2 di 2
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 Audio Jack Connector Replacement, Audio Jack Connector: passo 3, immagine 1 di 3 Acer Iconia B1-711 Audio Jack Connector Replacement, Audio Jack Connector: passo 3, immagine 2 di 3 Acer Iconia B1-711 Audio Jack Connector Replacement, Audio Jack Connector: passo 3, immagine 3 di 3
    • Unscrew 2x Philips screws
    • Disconnect and remove the Audio Jack Board flex cable.
    • Remove the board with the Audio Jack Connector.
Conclusione
ZFix
Membro da: 12/09/13
191.368 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
Un commento
Can anyone suggest part number for whole jack board or just of jack?
Alexander Zaripov - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 585
