Salta al contenuto principale
Acer Iconia A110 Speaker Replacement
Cosa ti serve
  1. Acer Iconia A110 Speaker Replacement, Battery: passo 1, immagine 1 di 2 Acer Iconia A110 Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Speaker Replacement: passo 2, immagine 1 di 3 Acer Iconia A110 Speaker Replacement: passo 2, immagine 2 di 3 Acer Iconia A110 Speaker Replacement: passo 2, immagine 3 di 3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Speaker Replacement: passo 3, immagine 1 di 3 Acer Iconia A110 Speaker Replacement: passo 3, immagine 2 di 3 Acer Iconia A110 Speaker Replacement: passo 3, immagine 3 di 3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
  4. Acer Iconia A110 Speaker Replacement, Speaker: passo 4, immagine 1 di 2 Acer Iconia A110 Speaker Replacement, Speaker: passo 4, immagine 2 di 2
    • With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
    • Two 2.0 mm screws (with the bigger head)
    • Four 2.5 mm screws (with the smaller head)
  5. Acer Iconia A110 Speaker Replacement: passo 5, immagine 1 di 2 Acer Iconia A110 Speaker Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • On the top right side of the motherboard, is the vibration motor. With tweezers, carefully pull the vibration motor out from underneath the motherboard.
    • The vibration motor is still connected to the motherboard by a small wire connection, so be careful not to rip the wire out.
    • With your fingers, carefully disconnect the cable securing the vibration motor to the motherboard. Set aside.
  6. Acer Iconia A110 Speaker Replacement: passo 6, immagine 1 di 2 Acer Iconia A110 Speaker Replacement: passo 6, immagine 2 di 2
    • The speaker located on the top of the motherboard should easily slide out. Take note that there is still a wire connected, so do so carefully.
    • With your fingers, slowly pull out the wire connecting the speaker to the motherboard.
Conclusione
Andrea
Membro da: 04/14/14
757 Reputazione
5 Guide realizzate
Cal Poly, Team 3-42, Maness Spring 2014 Membro di Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 21
Tutti i Tempi: 791
