Introduzione
If the sound from your speakers is distorted or absent, you may need to replace the speakers. This guide will show you the step-by-by process of removing or replacing the speakers module on your Acer Iconia Tab A100 device.
Cosa ti serve
Start at any side of the tablet.
Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
Work your way around the tablet.
Locate the speakers module, which consists of 2 square black speakers connected by wires.
Locate the white and blue Home Key FFC ribbon cable between the speakers.
Use the tip of a spudger or opening tool to lift up and flip the small hinge on the connector. Then gently pull the FFC ribbon cable out its connector socket.
