Salta al contenuto principale
Acer Iconia A1-830 Speaker Assembly Replacement
Cosa ti serve
  1. Acer Iconia A1-830 Speaker Assembly Replacement, Disassembling Acer Iconia A1-830 Back Panel: passo 1, immagine 1 di 2 Acer Iconia A1-830 Speaker Assembly Replacement, Disassembling Acer Iconia A1-830 Back Panel: passo 1, immagine 2 di 2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Speaker Assembly Replacement: passo 2, immagine 1 di 2 Acer Iconia A1-830 Speaker Assembly Replacement: passo 2, immagine 2 di 2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Speaker Assembly Replacement, Battery: passo 3, immagine 1 di 2 Acer Iconia A1-830 Speaker Assembly Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Speaker Assembly Replacement: passo 4, immagine 1 di 1
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Speaker Assembly Replacement: passo 5, immagine 1 di 2 Acer Iconia A1-830 Speaker Assembly Replacement: passo 5, immagine 2 di 2
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
  6. Acer Iconia A1-830 Speaker Assembly Replacement, Speaker Assembly: passo 6, immagine 1 di 3 Acer Iconia A1-830 Speaker Assembly Replacement, Speaker Assembly: passo 6, immagine 2 di 3 Acer Iconia A1-830 Speaker Assembly Replacement, Speaker Assembly: passo 6, immagine 3 di 3
    • Remove the small clear plastic cover from the speaker connector with the metal tweezers.
    • Lift out the speaker connector using the metal tweezers.
  7. Acer Iconia A1-830 Speaker Assembly Replacement: passo 7, immagine 1 di 1
    • Remove the two 2.8 mm Philips #00 screws using the #000 sized Philips screwdriver.
    • Remove the 3.7 mm Philips #000 screw using the #000 size Philips screwdriver.
  8. Acer Iconia A1-830 Speaker Assembly Replacement: passo 8, immagine 1 di 1
    • Lift out the speaker assembly form the plastic frame.
Conclusione
UMass Dartmouth, Team 4-6, Catania Fall 2015 Membro di UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 617
