Salta al contenuto principale
Acer Iconia A1-830 Battery Replacement
Cosa ti serve
  1. Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: passo 1, immagine 1 di 2 Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: passo 1, immagine 2 di 2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Battery Replacement: passo 2, immagine 1 di 2 Acer Iconia A1-830 Battery Replacement: passo 2, immagine 2 di 2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Battery Replacement, Battery: passo 3, immagine 1 di 2 Acer Iconia A1-830 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Battery Replacement: passo 5, immagine 1 di 2 Acer Iconia A1-830 Battery Replacement: passo 5, immagine 2 di 2
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
Conclusione
Altre 5 persone hanno completato questa guida.
UMass Dartmouth, Team 4-6, Catania Fall 2015 Membro di UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
3 Membri
5 Guide realizzate
2 Commenti
thnks is goood
mo7tarif1997 - Replica
Is it okay if the battery bends a slight bit when prying it off?
Doof - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 9,086
