Introduzione
The optical drive is a component that is prone to malfunctioning. When you insert a disc or CD into the optical drive, the optical drive reads and displays the information. If your computer is not properly reading the discs or if the optical drive is not opening, your optical drive may need to be replaced. Follow the instructions in this guide to replace the optical drive in your device.
Cosa ti serve
Power down the laptop prior to beginning.
Turn the laptop over with the battery closest to your body.
Remove the single screw that holds the optical drive in place using the Phillips #0 screwdriver.
