Salta al contenuto principale
Acer E5-571-54FL Optical Drive Replacement
Cosa ti serve
  1. Acer E5-571-54FL Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Optical Drive Replacement: passo 2, immagine 1 di 2 Acer E5-571-54FL Optical Drive Replacement: passo 2, immagine 2 di 2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Optical Drive Replacement: passo 3, immagine 1 di 2 Acer E5-571-54FL Optical Drive Replacement: passo 3, immagine 2 di 2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Optical Drive Replacement, Optical Drive: passo 4, immagine 1 di 1
    • Remove the single screw that holds the optical drive in place using the Phillips #0 screwdriver.
  5. Acer E5-571-54FL Optical Drive Replacement: passo 5, immagine 1 di 3 Acer E5-571-54FL Optical Drive Replacement: passo 5, immagine 2 di 3 Acer E5-571-54FL Optical Drive Replacement: passo 5, immagine 3 di 3
    • Slide out the old optical drive and remove it from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 447
