Salta al contenuto principale
Acer Chromebook cb3-532-c47c Display Assembly Replacement
Cosa ti serve
  1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: passo 1, immagine 2 di 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Display Assembly Replacement: passo 2, immagine 1 di 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the battery cable: passo 3, immagine 1 di 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: passo 4, immagine 1 di 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: passo 4, immagine 2 di 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: passo 5, immagine 1 di 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: passo 5, immagine 2 di 2
    • Deroute the black wifi wire from its slot in the palm rest.
  6. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: passo 6, immagine 1 di 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: passo 6, immagine 2 di 2
    • Deroute the white wifi wire from the slot in the palm rest.
  7. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: passo 7, immagine 1 di 3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: passo 7, immagine 2 di 3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: passo 7, immagine 3 di 3
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  8. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Right Hinge Screws: passo 8, immagine 1 di 1
    • Remove the two screws from the right hinge.
  9. Acer Chromebook cb3-532-c47c Display Assembly Replacement: passo 9, immagine 1 di 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement: passo 9, immagine 2 di 2
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  10. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Left Hinge Screws: passo 10, immagine 1 di 1
    • Remove the two screws from the left hinge.
  11. Acer Chromebook cb3-532-c47c Display Assembly Replacement: passo 11, immagine 1 di 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement: passo 11, immagine 2 di 2
  12. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: passo 12, immagine 1 di 3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: passo 12, immagine 2 di 3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: passo 12, immagine 3 di 3
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
Conclusione
Jerry Wheeler
Membro da: 03/21/22
58.494 Reputazione
69 Guide realizzate
Oregonians Membro di Oregonians
Community
8 Membri
176 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 296
