Salta al contenuto principale
Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement
Cosa ti serve
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Back Cover: passo 1, immagine 1 di 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: passo 2, immagine 1 di 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: passo 2, immagine 2 di 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: passo 2, immagine 3 di 3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Battery: passo 3, immagine 1 di 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Battery: passo 3, immagine 2 di 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Remove the ribbon cable by pulling the plastic connector that is connected to the motherboard out.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the laptop by hand.
Conclusione
Evan Costa
Membro da: 10/29/19
503 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,664
