Salta al contenuto principale
Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement
Cosa ti serve
  1. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, LCD Screen & Digitizer Assembly: passo 1, immagine 1 di 2 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, LCD Screen & Digitizer Assembly: passo 1, immagine 2 di 2
    • Separate screen casing using a nylon spudger and a metal spudger.
  2. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 2, immagine 1 di 1
    • Peel the tape back.
    • Lift the red bar laying across the connection with the spudger.
    • Pull the connection out.
  3. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 3, immagine 1 di 2 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 3, immagine 2 di 2
    • Disconnect the two cords shown by gently pulling them apart near their connection point.
  4. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 4, immagine 1 di 1
    • Detach the connection by gently pulling on it.
  5. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 5, immagine 1 di 1
    • Unravel the cord from around the screen and lift up on the screen to remove.
  6. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, Display Assembly: passo 6, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove all twelve 6 mm screws in the bottom panel of the Chromebook.
  7. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 7, immagine 1 di 2 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 7, immagine 2 di 2
    • Use an opening tool to pry open the Chromebook casing starting from the corners.
  8. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the 6 mm hinge screws on the right side of the Chromebook.
  9. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 9, immagine 1 di 2 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 9, immagine 2 di 2
    • Disconnect the end of LCD cable that is connected to the motherboard. Lift the connector's ZIF tab and gently pull the ribbon cable free.
    • Disconnect the other end of the LCD cord from the left side of the motherboard.
  10. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: passo 10, immagine 1 di 1
    • The LCD cable has been disconnected and can be removed by guiding it out of the hooks that keeps it in placed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 520
