Salta al contenuto principale
Acer Chromebook R11 Speakers Replacement
Cosa ti serve
  1. Acer Chromebook R11 Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • The back cover of the R11 is held into place using 11 screws.
    • To remove, use a screwdriver appropriate for a JIS 1 screw.
  2. Acer Chromebook R11 Speakers Replacement: passo 2, immagine 1 di 1
    • Battery is located in the bottom half of the computer.
    • Unscrew the two screws holding the battery in place. There is one on each side of the battery.
  3. Acer Chromebook R11 Speakers Replacement: passo 3, immagine 1 di 1
    • Slide out the ribbon that is connecting the battery to the motherboard.
    • There are 7 wires leading to it, and each is a different color of the rainbow.
    • Disconnect the keyboard ribbon located at bottom center of motherboard.
  4. Acer Chromebook R11 Speakers Replacement: passo 4, immagine 1 di 1
    • Remove the battery by pulling upwards.
  5. Acer Chromebook R11 Speakers Replacement, Speakers: passo 5, immagine 1 di 2 Acer Chromebook R11 Speakers Replacement, Speakers: passo 5, immagine 2 di 2
    • Slide out black ribbons connecting speakers to motherboard
    • Connected on lower left-hand side of motherboard
    • When removing wires, remove gently with respect to metal clips along wires that are holding them in place.
    • Slide out white ribbon connecting keyboard to motherboard
  6. Acer Chromebook R11 Speakers Replacement: passo 6, immagine 1 di 1
    • Gently pull speakers upwards
    • Adhesive is below it
Conclusione
Victoria May
Membro da: 02/16/17
119 Reputazione
1 Guida realizzata
USF Tampa, Team 1-2, Kass Spring 2017 Membro di USF Tampa, Team 1-2, Kass Spring 2017
USFT-KASS-S17S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 522
