Salta al contenuto principale
Acer Chromebook R11 C738T-C44Z Wireless Card Replacement
Cosa ti serve
  1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: passo 1, immagine 3 di 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: passo 2, immagine 1 di 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: passo 2, immagine 2 di 2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  3. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  4. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: passo 4, immagine 1 di 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: passo 4, immagine 2 di 2
    • Carefully slide the wireless card out of its socket from the motherboard.
Conclusione
Gateway, Team 1-4, Saknee Fall 2021 Membro di Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 340
