Salta al contenuto principale
Acer Chromebook R11 C738T-C44Z Touchpad Replacement
Cosa ti serve
  1. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: passo 1, immagine 3 di 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: passo 2, immagine 1 di 2 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: passo 2, immagine 2 di 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: passo 3, immagine 1 di 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: passo 4, immagine 1 di 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: passo 5, immagine 1 di 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: passo 5, immagine 2 di 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: passo 5, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the touchpad.
    • Lift up the tab for the cable cord.
    • Pull out the touchpad connector.
  6. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: passo 6, immagine 1 di 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement: passo 6, immagine 2 di 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement: passo 6, immagine 3 di 3
    • Pull the left piece of tape up by prying it up with your fingers or with the screwdriver.
    • Be gentle to not rip the tape.
    • Next, pull up the other piece of tape.
    • Remove the touchpad.
Conclusione
Gateway, Team 1-4, Saknee Fall 2021 Membro di Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Membri
6 Guide realizzate
Un commento
Thank you, Connie Fernandez. ~Super
Super - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 328
