Salta al contenuto principale
Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement
Cosa ti serve
  1. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement, Battery: passo 1, immagine 1 di 2 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop over so that the backside is facing up.
    • Use a Phillips #0 screwdriver to remove nine screws along the perimeter of the back case.
    • Use an opening tool to pry the case around the perimeter and gently release the clips attaching the back case to the front.
    • Lift the back case off of the Chromebook.
  2. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 2, immagine 1 di 2 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove two screws on either side of the battery.
  3. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 3, immagine 1 di 2 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 3, immagine 2 di 2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out to disconnect the battery from the motherboard.
  4. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 4, immagine 1 di 2 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 4, immagine 2 di 2
    • Remove the battery from the Chromebook.
Conclusione
Matthew Supplee
Membro da: 09/22/22
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 150
