Salta al contenuto principale
Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement
Cosa ti serve
  1. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Back Cover: passo 1, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Back Cover: passo 1, immagine 2 di 2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: passo 2, immagine 1 di 3 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: passo 2, immagine 2 di 3 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: passo 2, immagine 3 di 3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: passo 3, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Battery: passo 4, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Battery: passo 4, immagine 2 di 2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Wi-Fi Card: passo 6, immagine 1 di 1
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  7. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: passo 7, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: passo 7, immagine 2 di 2
    • Remove the single 3 mm screw using a Phillips #1 screwdriver.
  8. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: passo 8, immagine 1 di 1
    • Gently pull the wireless card away from the motherboard to remove it.
Conclusione
Aida mohamed
Membro da: 02/08/22
186 Reputazione
1 Guida realizzata
Gateway, Team 1-1, Saknee Spring 2022 Membro di Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 147
