Salta al contenuto principale
Acer Chromebook CP5-471-C0EX Trackpad Replacement
Cosa ti serve
  1. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: passo 1, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: passo 1, immagine 2 di 2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 2, immagine 1 di 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 2, immagine 2 di 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 2, immagine 3 di 3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 3, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 3, immagine 2 di 2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: passo 4, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: passo 4, immagine 2 di 2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 5, immagine 1 di 1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: passo 6, immagine 1 di 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: passo 6, immagine 2 di 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: passo 6, immagine 3 di 3
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  7. Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 7, immagine 1 di 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 7, immagine 2 di 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 7, immagine 3 di 3
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  8. Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 8, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 8, immagine 2 di 2
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 9, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: passo 9, immagine 2 di 2
    • Carefully remove the trackpad from the device.
Conclusione
Gateway, Team 1-1, Saknee Spring 2022 Membro di Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 119
