Salta al contenuto principale
Acer Chromebook CP5-471-C0EX Fan Replacement
Cosa ti serve
  1. Acer Chromebook CP5-471-C0EX Fan Replacement, Back Cover: passo 1, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Fan Replacement, Back Cover: passo 1, immagine 2 di 2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Fan Replacement: passo 2, immagine 1 di 3 Acer Chromebook CP5-471-C0EX Fan Replacement: passo 2, immagine 2 di 3 Acer Chromebook CP5-471-C0EX Fan Replacement: passo 2, immagine 3 di 3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Fan Replacement: passo 3, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Fan Replacement: passo 3, immagine 2 di 2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Fan Replacement, Battery: passo 4, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Fan Replacement, Battery: passo 4, immagine 2 di 2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Fan Replacement: passo 5, immagine 1 di 1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Fan Replacement, Fan: passo 6, immagine 1 di 2 Acer Chromebook CP5-471-C0EX Fan Replacement, Fan: passo 6, immagine 2 di 2
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  7. Acer Chromebook CP5-471-C0EX Fan Replacement: passo 7, immagine 1 di 3 Acer Chromebook CP5-471-C0EX Fan Replacement: passo 7, immagine 2 di 3 Acer Chromebook CP5-471-C0EX Fan Replacement: passo 7, immagine 3 di 3
    • Unwind the Wi-Fi card wires from the side of the fan.
    • The wires need to be pulled down and around the first hook, as seen in image two.
    • Pull the black and white cables under the second hook and away from the fan.
  8. Acer Chromebook CP5-471-C0EX Fan Replacement: passo 8, immagine 1 di 3 Acer Chromebook CP5-471-C0EX Fan Replacement: passo 8, immagine 2 di 3 Acer Chromebook CP5-471-C0EX Fan Replacement: passo 8, immagine 3 di 3
    • Pull wires so they are out the way.
    • Loosen the six screws from the fan and heat sink.
    • The two screws closest to the fan cannot be removed from the fan, but will still loosen from the case.
  9. Acer Chromebook CP5-471-C0EX Fan Replacement: passo 9, immagine 1 di 3 Acer Chromebook CP5-471-C0EX Fan Replacement: passo 9, immagine 2 di 3 Acer Chromebook CP5-471-C0EX Fan Replacement: passo 9, immagine 3 di 3
    • Gently lift the fan out of the case, but do not remove it fully; there is still one more cable attached.
    • Pull the cable out of its socket on the motherboard.
    • Remove the fan from the laptop.
Conclusione
Cody Venne
Membro da: 02/08/22
133 Reputazione
1 Guida realizzata
Gateway, Team 1-1, Saknee Spring 2022 Membro di Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 111
