Salta al contenuto principale
Acer Chromebook CB5-571-C5XU Trackpad Replacement
Cosa ti serve
  1. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Bottom Case: passo 1, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Trackpad Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 2, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 2, immagine 2 di 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Battery: passo 3, immagine 1 di 1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 4, immagine 1 di 1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 5, immagine 1 di 1
    • Gently lift the battery out and remove it from the laptop casing.
  6. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Trackpad: passo 6, immagine 1 di 1
    • Unhook the black ribbon from the motherboard, using the opening tool to pull the hooks in the direction of the arrows.
    • Once the hooks are released, simply pull the black ribbon outward to remove it from the motherboard.
  7. Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 7, immagine 1 di 3 Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 7, immagine 2 di 3 Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 7, immagine 3 di 3
    • Using a Phillips #0 screwdriver, remove the 7 screws holding the trackpad in place.
    • The metal piece at the bottom edge of the laptop will lift off after the screws are removed.
  8. Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 8, immagine 1 di 1
    • Use the spudger tool to unhook the locks on both sides of the end of the white ribbon. Pull the ribbon outward away from the motherboard.
  9. Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 9, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Trackpad Replacement: passo 9, immagine 2 di 2
    • Use the spudger tool to pry the trackpad up and away from the laptop.
Conclusione
David Flint
Membro da: 10/17/17
273 Reputazione
2 Guide realizzate
2 Commenti
How do I remove the touchpad from the backing/bracket? The replacement touchpad I bought has none of the metal bracket, and I believe I need to remove it from my old broken one.
Shawn H - Replica
For the record I ended up having to purchase a new mounting bracket separately and affix it ($5). Hope this helps someone. I’ve done the repair but the trackpad is still not functioning. Not sure what the issue is but the swap was pretty easy.
Shawn H - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 331
