Salta al contenuto principale
Acer Chromebook CB5-571-C5XU Solid State Drive Replacement
Cosa ti serve
  1. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: passo 1, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: passo 2, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: passo 2, immagine 2 di 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Solid State Drive: passo 3, immagine 1 di 1
    • Using the Phillips #0 Screwdriver, unscrew the single screw holding the Solid State Drive in place.
  4. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: passo 4, immagine 1 di 1
    • Gently lift the Solid State Drive upwards at an angle until it stops.
    • Be careful not to lift the Solid State Drive past where it stops, or you will risk breaking the hardware.
  5. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: passo 5, immagine 1 di 1
    • Pull the Solid State Drive out from the socket in the direction of the angle at which it was resting.
    • The Solid State Drive should pull out with little effort. If it is resisting, do not pull harder, as this risks damage to the part.
Conclusione
Altre 2 persone hanno completato questa guida.
David Flint
Membro da: 10/17/17
273 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 444
