Salta al contenuto principale
Acer Chromebook CB5-571-C5XU Fan Replacement
Cosa ti serve
  1. Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: passo 1, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Fan Replacement: passo 2, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Fan Replacement: passo 2, immagine 2 di 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: passo 3, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Using a Phillips #0 screwdriver, unscrew the screw to the right of the fan.
    • Remember to have a small container to place the screw in, so it does not get lost.
  4. Acer Chromebook CB5-571-C5XU Fan Replacement: passo 4, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Fan Replacement: passo 4, immagine 2 di 2
    • Using the Phillips #0 screwdriver, unscrew the four screws connecting the heatsink to the motherboard.
    • Remember to have a safe place to place the screws, so none of them get lost.
  5. Acer Chromebook CB5-571-C5XU Fan Replacement: passo 5, immagine 1 di 3 Acer Chromebook CB5-571-C5XU Fan Replacement: passo 5, immagine 2 di 3 Acer Chromebook CB5-571-C5XU Fan Replacement: passo 5, immagine 3 di 3
    • Carefully unhook the black and white wires from the circumference of the fan.
    • It might help to use the pointed end of the spudger tool to unhook the wires.
    • Do not tug too hard on the wires, as they can easily disconnect and snap off from the motherboard.
  6. Acer Chromebook CB5-571-C5XU Fan Replacement: passo 6, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Fan Replacement: passo 6, immagine 2 di 2
    • Using the spudger tool, carefully remove the wires connecting the fan to the motherboard.
  7. Acer Chromebook CB5-571-C5XU Fan Replacement: passo 7, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Fan Replacement: passo 7, immagine 2 di 2
    • Using the flat side of the spudger, firmly pry the fan off of the components, as well as the heatsink from the motherboard.
Conclusione
Erin Moffatt
Membro da: 10/17/17
282 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 298
