Salta al contenuto principale
Acer Chromebook CB5-571-C5XU Battery Replacement
Cosa ti serve
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: passo 1, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: passo 2, immagine 1 di 2 Acer Chromebook CB5-571-C5XU Battery Replacement: passo 2, immagine 2 di 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: passo 4, immagine 1 di 1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: passo 5, immagine 1 di 1
    • Gently lift the battery out and remove it from the laptop casing.
Conclusione
To reassemble your device, follow these guidelines in reverse order.
Altre 3 persone hanno completato questa guida.
Kenneth Bowers
Membro da: 04/08/16
1.432 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 14
Tutti i Tempi: 859
