Salta al contenuto principale
Acer Chromebook CB315-3HT-C3FQ Speaker Replacement
Cosa ti serve
  1. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Flip the Chromebook over so the bottom is facing up.
  2. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: passo 2, immagine 1 di 1
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
  3. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: passo 3, immagine 2 di 2
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
  4. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: passo 4, immagine 1 di 2 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: passo 4, immagine 2 di 2
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
  5. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Speaker: passo 5, immagine 1 di 3 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Speaker: passo 5, immagine 2 di 3 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Speaker: passo 5, immagine 3 di 3
    • Unplug the speaker cord from the motherboard's port.
    • Remove the speakers from the laptop.
    • Scan the QR code located in between the left and right speakers. The QR code will take you to different sites that sell the internal speakers that are for the Acer Chromebook 315.
Conclusione
Kyle
Membro da: 03/20/24
327 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 28
