Salta al contenuto principale
Acer Chromebook CB315-3HT-C3FQ Battery Replacement
Cosa ti serve
  1. Acer Chromebook CB315-3HT-C3FQ Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Flip the Chromebook over so the bottom is facing up.
  2. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: passo 2, immagine 1 di 1
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
  3. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB315-3HT-C3FQ Battery Replacement: passo 3, immagine 2 di 2
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
  4. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: passo 4, immagine 1 di 2 Acer Chromebook CB315-3HT-C3FQ Battery Replacement: passo 4, immagine 2 di 2
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
  5. Acer Chromebook CB315-3HT-C3FQ Battery Replacement, Battery: passo 5, immagine 1 di 2 Acer Chromebook CB315-3HT-C3FQ Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the thermal tape that covers the wires connecting the battery to the motherboard.
    • Move the thermal tape to the side so you can put it back on afterwards.
  6. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: passo 6, immagine 1 di 2 Acer Chromebook CB315-3HT-C3FQ Battery Replacement: passo 6, immagine 2 di 2
    • Unplug the bundle of wires that connect the battery to the motherboard.
    • Remove the battery from the laptop.
Conclusione
brocha2
Membro da: 03/20/24
135 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 58
