Salta al contenuto principale
Acer Chromebook CB3-431-C5EX Wireless Card Replacement
Cosa ti serve
  1. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: passo 2, immagine 1 di 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Wireless Card Replacement: passo 3, immagine 2 di 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • Remove the 4mm Phillips #0 screw securing the wireless adapter to the main circuit board.
  5. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: passo 5, immagine 1 di 1
    • Unplug the Wireless adapter from the main circuit board by giving the adapter light pressure and sliding it out of its port.
  6. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: passo 6, immagine 1 di 1
    • Detach the two cables from the Adapter by pulling directly up on them, and then remove the adapter.
    • Note that the black cable is already detached in this photo to show what it looks like with the cables removed.
    • Be sure to note the original locations of the black and white cables when installing the new wireless adapter.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S17-G3, Banghart Spring 2017 Membro di Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,463
