Introduzione
This repair guide is designed to instruct you on how to replace the wireless adapter in your Chromebook. All you will need for this replacement is a Phillips #0 screwdriver and a plastic spudger. Remember to completely power down your Chromebook before working on it, and handle the internal components of you Chromebook with care as they are fragile.
Cosa ti serve
Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
Remove the bottom panel and set it aside.
Remove the 4mm Phillips #0 screw securing the wireless adapter to the main circuit board.
Altre 3 persone hanno completato questa guida.
