Salta al contenuto principale
Acer Chromebook CB3-431-C5EX Trackpad Replacement
Cosa ti serve
  1. Acer Chromebook CB3-431-C5EX Trackpad Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 2, immagine 1 di 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 3, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 3, immagine 2 di 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Trackpad Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 5, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 5, immagine 2 di 2
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 6, immagine 1 di 1
    • Carefully lift the entire battery pack out of the laptop.
  7. Acer Chromebook CB3-431-C5EX Trackpad Replacement, Trackpad: passo 7, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Trackpad Replacement, Trackpad: passo 7, immagine 2 di 2
    • Remove the black tape covering the screws connecting the trackpad to the laptop.
  8. Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 8, immagine 1 di 1
    • Remove the three 2.5 mm screws that are securing the trackpad to the laptop using a Phillips #0 screwdriver.
  9. Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 9, immagine 1 di 2 Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 9, immagine 2 di 2
    • Lift up the black retaining flap on the connector.
    • Slide the blue ribbon cable out of the connector.
  10. Acer Chromebook CB3-431-C5EX Trackpad Replacement: passo 10, immagine 1 di 1
    • Lift up the body of the laptop and slide the trackpad out from beneath.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 191
